Zum Hauptinhalt wechseln
Die Wi-Fi Version des iPad Air mit der Modellnummer A1474 ist in Space Grau und Silber erhältlich. Sie enthält einen A7 Prozessor und ist mit 16, 32, 64 oder 128 GB Speicherkapazität erhältlich.
299 Fragen Alle anzeigen
Problems after iPad digitizer replacement - boot screen, home button
Hi folks,
Just replaced a crushed digitizer on an iPad Air gen1, hurray for new things learned. However, after I did the tear down and put it back together I seem to have a few issues:
1) when I turn on the ipad after the apple welcome logo, it goes black unless I hold down the power button to shut it off. That's when I get the slide to power off screen. After I cancel that I get the "click home button to unlock" but that's when I discover my second issue...
2) the home button on my new front panel replacement doesn't seem to work. I took it apart a second time and made sure that the slide connector and the latch are securely in place and I put that little black tape that was on the original back and still the same thing. At first it wast sticky so I thought I had just put it together wrong so I took it apart and made sure there wasn't anything gumming up the button travel.
Thoughts anyone?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
the new digitizer needs shielding. check jessa's post on her site iPad rehab where she talks about the iPad mini revealing it's secrets to her. you should get by with just shielding across the bottom of the digitizer on the inside, cover all the copper looking area. also if you check with the digitizer up not put down, I'm sure it behaves properly once booted up.
Update (01/26/2017)
could be a faulty home button, for sure a shielding thing with it working properly when up. are you sure that the home button was put in right? the gold part at the end of the home button flex needs to be facing up.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Hi Richard,
Thanks for responding. I also didn't clean out the old adhesive very well so it's easy to take the thing apart still... guess I might need a new adhesive set. It was behaving fine with the digitizer up, so something must be happening when I'm sealing it up, or perhaps I'm pinching the LCD cable when I seal it up.
Though the home button still doesn't work even when the digitizer is up. Could it be a faulty home button assembly? I don't think I mis-treated it...
Thoughts?
-Gary
von
Antwort hinzufügen
Gary Yee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 69
