Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Small Metal Part Fell Out?
I was replacing my brother's iPhone 5 battery and after opening the screen panel a small metal part with two holes fell out and I have no idea where it goes. Also, this black strip towards the home button appears loose and I'm not sure where that goes, either.
Photos below:
https://goo.gl/photos/cRzqfSffKxCntwVE9
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
the small metal part on the left hold the home button flex in place once you connect it. is there a screw on the home button flex to the right when you're looking at the back of the lcd? if you lost if you could just use a bit of double sided tape I guess where the screw ought to be.
Update (01/26/2017)
you're welcome, you could even forget about the metal part, it won't matter anything if you do, it's a headache to put back. I do it for customers of course but if it was mine....depends on my mood if i were to put it back. it needs to first get set into the top area, there are two notches in it then forced down towards the bottom. you're welcome!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Ah, I see! Thanks for the insight. It appears I lost the screws but I will definitely try tape. Thanks again!
von
Antwort hinzufügen
Hannah D wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 145
