Zum Hauptinhalt wechseln
A pico projector designed to work with Apple products.
5 Fragen Alle anzeigen
no projection or light
Continuation has the purchase of a cinemin swivel, I have a problem:
When I switch on the pico connected to an ipod, an image is projected with the cinemin logo; but two seconds after, nothing more no projection or light which goes out of the device.
By looking the lens I has fault sees a small light at the bottom of the device
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Any fix for this problem with the swivel?
von
nyl777, it would work so much better for you if you ask your own question and give as much detail as possible if you are expecting any help with your device. Your two questions on ifixit actually show up as answer to older questions. Click on the link on the right hand side of this page, where it says" Ask a question" Give it a try, it is not difficult and you may get some help for your problem. Good Luck.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Sounds Like a the bulb has burnt out. Hopefully its not to expensive.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
How to be safe that It is the bulb, because the device does not have was used
von
He reacts in the same way when no device is above connected
von
Are you using it with an iPhone, iPod, or iPad? Because if you are, you need to use the little adapter. It should plug into the charger port of the iProduct, not the headphone port, and then the 3.5mm plugs right into that. I had this same problem, until I noticed the adapter lol
Bewertung 0
It may be the cord or the adapter. Sometimes, I have to plug my DVD player white into the yellow, and the yellow into the white in order to get the picture. It's like a crossed wire or something.
Bewertung 0
Does anybody know where I can find the blue cord that connects the cinemon swivel 8410 projector component with the battery component?
Bewertung 0
Antwort hinzufügen
specie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 2,907
