Zum Hauptinhalt wechseln
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
262 Fragen Alle anzeigen
How to change the chip NAND
My nintendo fell to the ground, and because of that it does not work properly, but, the console gives life signals when you connect it to the mains. So I decided to buy another nintendo dsi (that was the model that fell me) to be able to remove this console NAND chip and replace it with my old nintendo. Someone could help me.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
What makes you believe its an issue with the NAND?
von
No, the problem is not the chip, but I want to change the NAND chip from my old console to another console
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Have you looked at the tear down guide if you exchange the whole logic board from Step 16 that should be easy to do. But if you want to get the Nand chip of then you would need special solder ecuipment to do it.
Nintendo DSi Teardown
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Actually, a full NAND chip replacement is impossible due to the per-console encryption applied to it. You would have to transplant not only the NAND, but also the CPU.
von
Antwort hinzufügen
[deleted] wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 36
Insgesamt: 962
