How can I boost my signal for my fire tv stick
i live in a mobile home and i use a friends wifi but i dont think his wifi signal is strong enough to run my fire tv stick from across the street can i fix this problem with a wifi antanna if so what is the best antanna to use
Ist dies eine gute Frage?
3 Kommentare
my firestick cable keep stopping. I could be watching a movie then this little circle shows up 1 2 3 it stays on three for about 2 minutes then the movie comes back on. Shortly after that the little circle comes back on again this time it stays on that Circle for about 5 minutes then the movie comes back on this happens all the time. Note I have Wi-Fi in my home do you think buying this piece from Amazon will help
von Gxx24u123
no, this item will not help you, the circle you see spinning is when the device is working or waiting... being that you are using a firestick.. I would think it is buffering the movie/stream or whatever you are watching. I would suggest looking at your internet speed or modem/router for issues there.
von Richard Simpson
I have a similar issue with watching programs using my firestick. My speed is about 240 at the TV but it falls to about 40 when I complete a speedtest for my firestick. I changed my modem/router which now has a speed of 600+ at the router. The 240 speed at the TV is more than enough but the firestick is not picling up this speed. I even installed a connector which improved the speed to the TV but not to the firestick. Is there something wrong with the firststick itself. I have a HD $K firestick.
von Hiram Sem
