Zum Hauptinhalt wechseln
Dritte Generation des Surface Pro Tablets ab 20.Juni 2014
123 Fragen Alle anzeigen
UEFI locked for upgrade prts including display?
I have a SP3 with a cracked screen, it works fine other than no touch feature. I also have a Same model SP3 thats UEFI locked. but the display works, it has a bigger SSD and more Ram. Can i use these parts to upgrade my broken/budget ass one?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The SSD is upgradable as it uses mSATA SSDs that are removable.
The screen however good luck removing it without cracking it. I have gotten someone to remove it without cracking it or damaging it which is impressive.
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
Do you know of a way to wipe the UEFI lock with a software hack or hardware adjustment?
von
what hardware stores do you UEFI bios password on a surface pro three?
von
No it's not possible as hard as Apple iCloud lock.
von
I already tried bios swap
von
Antwort hinzufügen
Bradley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 456
