Zum Hauptinhalt wechseln
Das Smart Battery Case ist eine Hülle für das iPhone 6s, das von Apple in Dezember 2015 auf den Markt gebracht wurde. Das Smart Battery Case hat einen integrierten Akku, um die Kapazität des iPhone 6s zu erhöhen.
Do you sell the replacement battery for this case?
My battery on the iPhone was completely dead and basically relying on the case's battery, then I ordered new battery for iphone on ifixit and replaced it, now the case wont even charge and is basically dead, there a particualr battery for it that you sell? The replacement looks relatively easy/.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hopefully this is still under warranty and you can get it replaced by Apple.
The teardown states:
"Battery replacement is possible, but will likely destroy the microfiber liner.
The only possible repair—replacing the battery—is made difficult by very strong adhesive."
War diese Antwort hilfreich?
Bewertung 4
4 Kommentare:
Yeah, I bought this case when it was released, needed the lightning connector that the mophie didnt have so I could use my carplay without removing phone each time. Purchase date was Jan 31st 2015 so I doubt its still under any warranty. Also, it only looks that I would mess up the interior felt lining which is hidden by the phone anyway, so it wouldnt really be a big eyesore, just getting the battery out from adhesive would be the most difficult.
von
I use a high grade alcohol (methanol) and a syringe and shoot it under batteries to loosen the glue. Works well on MBP glued in batteries.
von
this answer isn't helpful at all.. what is the type of battery and where can you buy it?
von
This answer isn't helpful at all.. what is the type of battery and where can I buy it?
von
I’m in the same boat, i have an 18650 laptop cell soldered to the the board of the apple battery to test and the smart case works and charges………………………………….but i cant seem to find a similar capacity battery of the proper dimensions, i dont even need an apple battery, i have the apple batteries connector desoldered and ready to be used w any battery i just need one that matches the dimensions of the case
Bewertung 0
Antwort hinzufügen
Christian Postier wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 30
Insgesamt: 1,921
