power windows not working
both front windows do not go up or down already tried switch and fuse
Ist dies eine gute Frage?
helgersonc, If equipped with some kind of child lock out control for windows check that the switch is in the correct position. If you have already eliminated the switches and fuses by testing, check for power to the switch. There is a good chance the wire harness that runs through the door jamb and door frame has become damaged. Take the protective wrap off in this area and check for pinched/damaged/broken wires.
Find below a couple links showing troubleshooting power windows. Good luck.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 3,501
1 Kommentar
Have you tested the switches for the windows in question with a multimeter to see if you are getting 12V DC at the switch when the ignition is turned to run/accessory?
von Geoff Ice
