Zum Hauptinhalt wechseln
Das LG G Pad 8.3 ist ein Tablet von LG Electronics Inc., das 312 g wiegt, 16 GB Speicher besitzt und über einen 8,3-Zoll-Bildschirm verfügt.
Got new battery for lg vk810 let it go dead
I got a new battery for lg 8.3 vk810 accidentally I let it completely die now I can't get it to charge or turn on I tried the 20second thing but it still won't do. anything. Also my screen is very dim?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare
lisasaunders528 "still won't do. anything. Also my screen is very dim?" so it does come on but has a very dim screen? Clarify this for us. A dead battery would not give you anything.
von Teilen
I replaced the battery and was working fine for a couple of days but then accidentally. Let it die now I can get it to charge or turn on
von Teilen
Sounds like you are having an issue with either your charging cable, your charger, or the charging port. Have you tried a different charger/cable?
von Teilen
Yes I've tried different cable and charger box it will sometimes show me the LG screen but can't get it to go past that I just ordered a new charger Port with flex cable so I hope it's the problem.
von Teilen
Also every once in a while I get a faded ring around the outside of the screen does that have anything to do with it or is that a hole new problem itself?
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Got the new flex cable in and its working great thank you for your help
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Try disconnecting the battery for a few minutes then replace battery and before turning it on plug it in and let it charge . Leave it plugged in for a day. see if this helps
just in case you need a guide
LG G Pad 8.3 Akku austauschen
Bewertung 2
3 Kommentare:
It's a new battery I just replaced it. And I let it charge over night
von Teilen
disconnect it then reconnect it before recharging . Connection may not have seated correctly . Check connection for dirt or lint
von Teilen
Installed. New flex cable and port and is working great now thank you
von Teilen
Antwort hinzufügen
lisasaunders528 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 2,667
