Zum Hauptinhalt wechseln
Das Galaxy S6 ist das neue Flagschiff der Galaxy-Linie. Es wurde im März 2015 angekündigt, Verkaufsstart war am 10. April. Die Version mit dem gewölbten Bildschirm ist unter Galaxy S6 Edge bekannt.
484 Fragen Alle anzeigen
Black screen with solid blue light after teardo, tried button restarts
Hi I recently took on a Samsung Galaxy s6 after a teardown but it's been given to me with black screen and a solid blue light which doesn't turn off, I've tried charging on Wall for a day, the charging led went from Blue to red after about an hour or so and started charging but the screen was still black and then I tried to turn it on again and it flashed a green/grey colour on the right hand side of the screen bit kind of faded to the middle and was black on the left, happened very quickly and I only just noticed it and the phone pretty much just did the same thing again..
I'm leaning to heat damage on the actual lcd because it looks like they've had a good go at taking it apart but I'm unsure as I thought the phone would still turn on and do everything as normal just with out any picture, specially without a solid blue light which makes me think it's something else.
Any input would be great as I've never come across this before and I have tried all the button restarts and so on possible to sort this and definitely think something needs replacing.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
this happened to me after i attempted a repair not sure what I did wrong assuming I somehow damaged the lcd did replacing it work?
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Try new LCD first would be my method
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Yeah comes this week so will let everyone know if it works
von
Any update on this?
I am curious if the new screen worked?
Bewertung 0
Hi. I have the same problem. Did you get it working again?
Bewertung 0
1 Kommentar:
I held the power volume and power buttons... it worked!!
von
Antwort hinzufügen
Dylan Swaby wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 8
Insgesamt: 3,574
