Zum Hauptinhalt wechseln
The HP Deskjet F4480 Printer/Copier/Scanner. This printer was intended for home or small office use.
19 Fragen Alle anzeigen
Printer will not print typed text.
I have a MacBook computer and an hp deskjet f4480 printer. My issue is that when I print some sort of template, example would be my W-2 form, with text typed in, all that prints is the template, none of the typed text. Why is this? What can I do to fix it? Obviously the printer is not reading the typed in information.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Printers print the information that is sent to it, printers do not have much processing capabilities. The problem is more likely to be in the settings of the print job or the page layout. What applications are you using to print? Can you do a print preview to see if the typed text is being added to the print job?
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
nathansdlr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 509
