What is F 01 Error code?
Ist dies eine gute Frage?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Be sure to unplug the washer before accessing internal components. When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time. Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer. Reassemble and test the washer.
War diese Antwort hilfreich?
I got F-01 on my Kenmore HE2. I took out the control board using instructions found on Youtube, but unlike the Youtubers, I did NOT have a blown solder joint. I racked my brains for what it could be. I decided to check the thermal fuse, which necessitated disassembling the dryer. When I did that, I saw that the belt was broken. So now the question is, did I have two problems (malfunctioning primary electronic control + broken belt) or just one problem (broken belt, fooling the electronic controls into an F-01 error code)? I called my local appliance parts store. They had a belt in stock for $25. I asked if a broken belt could cause an F-01 electronic control error, and he said he had never heard of that happening. This was a tough call because a replacement electronic control board is $150-$250 and the dryer is 10 years old. I decided to give it a shot replacing the belt. AND IT WORKED! Dryer seems to be fixed. There wasn't a problem with the electronic control board after all.
Letzte 24 Stunden: 10
Letzte 7 Tage: 38
Letzte 30 Tage: 149
Insgesamt: 23,519
1 Kommentar
If you have a soldering iron and are a DIY person, this is a free fix - https://youtu.be/eWqrn5klxm0
My control board looked identical to the one in the video.
von facebook.com
