Zum Hauptinhalt wechseln
Modelle A1181 / 1,83, 2, 2,1, 2,16, 2,2, or 2,4 GHz Core 2 Duo Prozessor
1203 Fragen Alle anzeigen
MB doesn't turn on after RAM upgrade
I am trying to change/upgrade the RAM of a MacBook 2.4GHz Intel Core 2 Duo from the original 2GB (2x1GB) to 4GB (2x2GB).
The new RAM I bought are Corsair 2GB DDR2 800Mhz .
Now, the Mac with the new 4GB of RAM doesn't boot up (nothing, apart the light display on the corner down on the right).
If I keep 1x1GB (original) and 1x2GB (new) it boots up (since I tried all the combinations, all the RAM works fine).
Any Idea? Thank you
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Let's first correctly identify your machine as there were 2008 & 2010 models of the 2.4 C2D machines.
von
Hi Mayer, thank you!
it is a 2008 (is 2242 Model, http://www.everymac.com/systems/apple/ma... )
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Try another brand. I've had Mac compatibility issues with Corsair personally. I switched to Kingston and Crucial, and haven't had any issues.
Also the speed absolutely has to match. Any faster it likely won't boot.
War diese Antwort hilfreich?
Bewertung 1
if is that the right model, you need pair of 667 MHz DDR2 SDRAM (PC2-5300)
of course both 800 Mhz didn't work, nice try:))
good luck
Bewertung 0
1 Kommentar:
I was afraid, it could have been that...I will try with 667MHz.
Thank you!
von
The RAM you are trying to use is incompatible with your model . You are trying to use 800 MHz RAM when that model only supports 667 MHz (PC2-5300). The reason why it works when you use the new ram in combo with old RAM, is that the old RAM is compatible. I am willing to bet if you looked in system specs, the Motherboard would only see your old RAM.
Bewertung 0
3 Kommentare:
Well, in the System specs I can see both, the new one and the old RAM (but it maybe doesn't support both 800MHz RAM .
Thanks!
von
RAM Type: PC2-5300 DDR2 Min. RAM Speed: 667 MHz
Details: Supports 667 MHz PC2-5300 DDR2 SDRAM.
Standard RAM: 2 GB Maximum RAM: 6 GB*
von
Thank you, Mayer
von
Antwort hinzufügen
luthdo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 173
