Zum Hauptinhalt wechseln
The Acer Aspire One 722 model #P1VE6 is a netbook that was released in July 2008.
Acer P1VE6 (Aspire One 722) charges but won't boot
Some time ago my son spilled water on top of the closed Acer Aspire one 722-0473. The water rolled off the top and entered through the touchpad/speaker area. When I plug it in, the orange charging light comes on. When I press the power button, the blue power light comes on. It even stays on after I unplug the laptop (battery is charging). When I took everything apart, I did not see any visible corrosion, but it still won't boot.
Do I need a new motherboard?
P.S. The only change I made the the original system was upgrading the hard drive. I purchased official ACER recovery discs.
Update (02/10/2017)
Looking at the touchpad's logic board, it's got some discoloration under what looks like tape (which is holding cables on). Can I peel that off to clean under it?
Update (04/27/2017)
I swapped the motherboard out, and now it is working beautifully!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@datnametakn , Stop charging and powering on the device. Even though you are not seeing corrosion it may be a good idea treat the board and all connections as if they had the corrosion/water on them (this way all connections,etc will be reseated well and clean). Disassemble the device Link #1 video for reference and a general guide Link #2 explaining drying/cleaning electronics that have experienced liquid damage.
Clean put back together and try. Good luck.
https://www.youtube.com/watch?v=PwttJ1L1...
Electronics Water Damage
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
datnametakn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 476
