Can it be hooked to a hard drive
I want to hook a external hard drive to the next book will it let me do this
Ist dies eine gute Frage?
Yes...WD Passport 1 TB external hard drive...for windows
War diese Antwort hilfreich?
James --
There are a couple of issues here: connectivity & power.
The Nextbook needs to provide enough power for whatever device you connect. Simplest test for this is to use a USB flash drive since they require little power. For a larger device, be sure the Nextbook is plugged in charging mode to provide the most power.
Next: What is the Operating System of your Nextbook?
Good luck,
Russ
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,639
2 Kommentare
Best way to find out is to just try it. Connect a USB drive, power up and see if it recognizes it.
von Russ Walden
Has anyone replaced the internal 32GB with more storage,or is it hardwired?
von Igor Schmidlapp
