Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1233 Fragen Alle anzeigen
No Sound from Ear Speaker
Hi
Wondering if you clever people could assist
I have a iphone 5c that has no sound from the ear speaker, i have replaced the front camera flex as well as the little black speaker, but i still cannot get any sound from the ear speaker.
Is there a chip or some other part on the board that controls this, or some obvious software setting
Thank you all
Update (02/25/2017)
Thank you all for your repsonse
So ive tried the following
1) Tried 2 new ear speakers
2) Tried 2 new flexes
3) Checked connector
All ok no obvious issues, is there a chip or something on the board that may be causing this issue?. If i try a factory reset will that work?
Regards
Ali
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Most likely, if you have replaced the front camera flex, as well as the speaker itself, it is either misaligned on the contacts (make sure that the contacts on the black speaker piece are aligned on the camera flex cable), misaligned on the logic board (check for misaligned flex cables on the logic board), or a pin has been broken on the logic board (disconnect the flexes for the display and camera, and check for any broken or damaged pins on the board). Other causes are far less likely, but could include:
  • Defective speaker
  • Defective Front Camera Flex
  • Other hardware or software issues
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Before taking apart my phone I would also double check that I didn't simply mute the speaker during a call or anything like that.
von
Antwort hinzufügen
Ali wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 116
