Zum Hauptinhalt wechseln
Vierte iPad-Generation, erstmals erhältlich am 2. November 2012 in Wi-Fi, CDMA und GSM Versionen mit 16, 32 oder 64 GB Speicher.
408 Fragen Alle anzeigen
Bottom part of digizer not working also charge issue
Customer brought in an Ipad 4, another shop just "repaired" it, screen wasn't sealed properly, bottom half of digitizer would not working and it won't charge. Installed a new battery, charge port and new digtizer. Same issue. Still not charging unless you reboot the device then it recognizes a charger is plugged in. Bottom half of digiziter does not work, made sure it was pushed all the way in. Did a hard reboot and reset settings
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Usually if a known good digitizer does not solve your partial touch issues, then one or both the digitizer connectors on the board are damaged.
As for the charging issue, you'll need to trouble shoot the charging circuit, but I've seen one working for a very long time now, that only recognizes chargers if you reboot them with one plugged in, then it will take a charge normally, and you can disconnect then reconnect the charger, it will remain operational. If you'd reboot without the charger, then it doesn't work.
We left it as is and it is still going strong :)
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
mikebarkas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 42
