Zum Hauptinhalt wechseln
Eine TV Spielkonsole von Sony Entertainment, auch bekannt als PS4. Sie wurde am 20. Februar 2013 angekündigt und kam am 15. November 2013 auf den Markt.
1697 Fragen Alle anzeigen
PS4 CUH-1215A - No HDMI signal
PS4 tries to give a signal (TV says "processing signal") but then it goes to "no signal."
Does this in both normal and safe mode.
PS4 seems to boot completely. Blue light turns white.
Known good TV and HDMI cable.
I am thinking of replacing the HDMI IC (Panasonic mn864729) but it is expensive.
Any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If the HDMI port looks good then it's is very likely to be the ic chip. The ic chips on these go out a lot more than the older models. I always check the port very carefully, test the diodes and resistors. If they are good then I replace the chip.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
Replaced the IC. Still the same problem. Diodes are all good. Port looks perfect inside and out. Sad!
von
Really? That's crazy...was it lightning damaged? I would replace the port as well just to be sure...sometimes one of the pins has a crack that you can't see. If you still can't fix it you could send it to me...I'll have a look at it if you'd like.
von
Mine doesn't show on My bigger LG screen but it's showing on the smaller one though the smaller is newer. What can I do to make it show on my bigger TV screen? Thanks as I await a solution to this issue
von
Still could be an hdmi port issue due to the resolution
Bewertung 0
Antwort hinzufügen
Matt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 2,950
