Hello guys thank you very much for taking time to answer me.
@jayeff : 1. Try using a different USB cable or connecting to a different USB port on your PC or even try on a USB port on a different computer. (This eliminates the USB cable, your computer's USB port(s) or your computer as a possible cause of the problem)
==> I have tried another USB cable + block to charge my phone and I am facing the same problem : it is only working when phone is OFF
"2. Inspect the USB port in the phone using a strong light and a magnifying glass.
a). Check that all 5 pins are there, especially the middle pins and that they are all straight and parallel with each other. (pins 2 & 3 are the data pins, 1 & 5 are the power pins, pin 4 is the 'sense' pin for use with OTG etc.)"
==> 5 pins are here and all straigth and parallel.
"b). Check that there is no lint or dust in the port enclosure. If there is use a vacuum cleaner with short sharp bursts to try and remove the lint or dust. If it is stubborn, try gently using a wooden toothpick to dislodge the debris. DO NOT use a metal probe and try not to damage the pins."
==> only at the entrance of the USB port it looks a bit like rust (because of the color) but on a very small part and not that close to the pins. Otherwise, nothing, everything is clean
"3. The USB port could be loose on the systemboard. "
==> I tried but nothing. And when it is a lil unplugged (like not very well plugged so you can have some ON/OFF charge), it is still only working when phone is OFF.
BTW Thank you very much for trying solving my problem.
@virgil Hey ! I am totally newbie for this kind of stuff. I did find the ADB Control for Root Users but what is Fastboot ?
Best regards
Nicola
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare
Please help me guys iam dyeing with this huawei y6prO i dont have a conputer i cant insert my sandisk usb drive in my phone its nit working
von Abhinav Chandra
This is the usual issue with every iPhone users and there is an easy solution that restarts your phone using a press and holds key till turn off and then restarts your system.
Visit the URL https://routerchatsupport.com/linksys-ro... for router issue and it helps you high-speed internet
von Sabhana Chaudhary
