Zum Hauptinhalt wechseln
Reparaturanleitungen für das MacBook Air, Apples aktuelle Serie für Consumer-Laptops.
4820 Fragen Alle anzeigen
My computer is typing the letter z constantly
my computer is typing the letter z constantly. I can barzely type this letter!z I took the key off, nothing is stuck. I reset the czomputer. It was an intermittent przoblem, but now seems permanent. Also, the letter z does not type when I press the keyz
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare
I have the same issue with z key. What was the problem with yours? Did you get fixed? How much was it to fix. Please share any info you have. Thanks.
von
i too havze this probzlemz.z funznyz is that it onzly types this letter after czertainz other letters: mz nz bz vz cz xz andz other letters are finez
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
It definitely sounds like the circuits responsible for the z key are started to ground, causing it to be seen as permanently pressed down by the system. This could either be a fault in the keyboard (which is most likely), or could be a motherboard issue. I would first try and clean out the connector - if it's still pressed down, then run the computer with the keyboard unplugged, and see if the issue persists. If yes, then it is a motherboard issue. If no, then it is an issue with the keyboard.
War diese Antwort hilfreich?
Bewertung 1
Try removing the back of the Macbook and disconnecting the keyboard from the logic board. Then connect a removable keyboard via usb. If the problem no longer occurs then you need to replace the keyboard of the macbook.
Bewertung 0
I plugged in an external keyboard and it worked then tried laptop keyboard and it works now too!
Bewertung 0
I have the same problem on my macbook air 2015 model. How to fix it pleasee help my Mac condition is really nice idk why it is happening ?
Bewertung 0
Antwort hinzufügen
Andrea wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 61
Insgesamt: 10,945
