Zum Hauptinhalt wechseln
Burning smell coming from hardware?
Hello, I have removed the display from the mac and unplugged from system, due to the backlight no longer working. Then when I plug it back in and power on the display the screen works but the backlight doesn't turn on and the casing smells like it's burning. Almost like when a capacitor continues to burn in a TV.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Keep the computer off and return it for repair. If you are local to an apple store, bring it in there.
Keep in mind that something as simple as a hair that fell on a heating coil and closed within your computer could produce this... or it could be a warning of imminent fire.
Problems with your magsafe and excessive heat or burning smells should prompt you to be sure to keep the device off.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Mag-safe on an iMac?
von
Antwort hinzufügen
Ryan Handy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 221
