Can I put a single cab transmission into a extra cab truck?
both trucks are 94 rangers both have same motor is the transmission going to match up with the driveline or will i need the driveline off single cab?
Ist dies eine gute Frage?
94 and 95 had Two transmissions for this truck A4LD which was with an overdrive and a 4R44E which was used till 2000 They both will work for you but you do need to measure the tail stock . As long as the tail stock are the same length then you wont have a problem.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 17
Insgesamt: 318
