How do I remove an ASA dial from Fuji Film Fujica ST605N camera?
How do I remove a ASA dial from a Fuji Film Fujica ST605N camera?
Ist dies eine gute Frage?
The ASA dial is screwed down by a single screw in the middle of the dial. Using plastic rod or wood dowel that is just the same diameter of the head of the screw which then has a piece of rubber attached to its end you can fashion a friction screwdriver to unscrew the slot-less screw.
Here is the service manual for the camera: Fujica ST605 service manual it's exactly the same as your ST605N.
War diese Antwort hilfreich?
Thank you I will let you know if this works. Thanks for pointing me in the right direction
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 1,209
