Zum Hauptinhalt wechseln
Backlight always on when inverter changed
Hi, I changed the inverter on my macbook pro santa rosa (a1226) because there was no backlight anymore. Its a glossy screen and I put an inverter from the same model but from a mate screen. The problem is when I put the battery on, the screen is lighting.. when I power on the Mac book, it works well, I have my screen back but when I press light up or light down on the keyboard, it has no effect on the screen. What should I do ? I also change the inverter cable.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
fab.breek this is usually caused by an inverter issue. In your case it is entirely possible that you have a wrong/different internal wiring invert. Replace it with a proper model inverter and let us know what happened.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
fab.breek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 33
