Zum Hauptinhalt wechseln
Das Apple iPhone 5c wurde am 10. September 2013 angekündigt. Ausgerüstet mit Schraubenziehern und Hebelwerkzeugen, geht die Reparatur ähnlich vonstatten wie bei den Vorgängermodellen. Verfügbar mit GSM oder CDMA mit 8, 16 oder 32 GB in weiß, pink, gelb, blau und grün.
1233 Fragen Alle anzeigen
earpiece not working but in different phone is working
Hi everyone
I have problem with one iPhone 5C, the earpiece won't work but if you press on it works.
I replace the screen with new earpiece and new proximity flex that are working in different device and still it doesn't work when I place back in the phone.
Anyone had this issue before?
Thank you for your help
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Could it be the screen frame? I've seen screen frames where they have caused horrible installation of the metal plate and two screws for the earpiece / front camera assembly.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Hi Ben,
I have tried with numerous screens and is still not working.
I have put full assembly screen with all installed that work in different phone and when I put it in the one with the issue doesn't want to work.
So I guess it is not the screen it is motherboard issue but I don't know where to look and what to do.
If you have any ideas I will appreciate the help.
von
Probably you have damaged the J1 connector or a part near this connector. See the schematic, check pins 24,26,28 and parts that connect to this pins.
Bewertung 0
1 Kommentar:
Thank you very much for your answer.
The phone came with this problem and I just couldn't fix it :)
I will check this pins and see if any of them are damaged.
von
Antwort hinzufügen
Mimi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 7
Insgesamt: 64
