My laptop keeps shutting down?
I have a toshiba satellite laptop. I had a cracked screen that i just replaced. However, upon turning it back on the new screen lit up for about 3 seconds and then went black. And then about a minute later the computer turned off. I tried removing the battery and trying that shift/f8/power trick but that did not work either. I am wondering what is wrong with my computer and how can i fix it. I am willing to try anything, thanks.
Ist dies eine gute Frage?
3 Kommentare
What does it do now when you try to turn it on? Was it new or used or OEM replacement screen, was the computer still functioning fine with old screen, do you hear fan's/hard drive running? Have you tried an external monitor.
von L Pfaff
When it turns on, the screen lights up, and its running. But after about 10 seconds the screen goes completely black and then the computer turns off. I have however noticed that the screen has been staying on longer. It was a new screen that i used for the replacement. While the screen was cracked the computer still worked, i just couldnt seen all of the screen since it was cracked. And the fan turns on when i turn on the computer. And im not sure how do the external moniter. I dont think i have an hdmi cable.
von Alaina
Update: i found an hdmi cable and hooked up my laptop. The display is showing up on my tv.
von Alaina
