Zum Hauptinhalt wechseln
HP Deskjet 3530 All-in-One Printer Series - Regulatory Model Number: SNPRH-1102
7 Fragen Alle anzeigen
Why does printer continue to jam after removing jammed paper?
Printer continues to jam when trying to print. This occurs after clearing jammed paper. Paper does not advance after being pulled into printer. Does not feed under rollers before ink cartridges.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
A very common issue with all printers is the rubber pinch rollers loose their grip from the paper dust so I would start off by carefully cleaning the rollers with cotton swabs (Q-Tips) and isopropyl alcohol. You may want to use a small paint brush to scrub down the parts and a can of can'ed air to blow the dust away. Just be careful you don't snag a part with the brush pulling it off.
Start there and let us know how it goes.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
jeansheehy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 250
