Zum Hauptinhalt wechseln
Angekündigt im März 2015, erschien das Samsung Galaxy S6 Edge am 10. April 2015, als die Version mit gekrümmtem Bildschirm von Samsung neustem Flaggschiff-Smartphone.
Touch screen not working?
So I broke the screen on my s6 edge and the phone worked fine for a while. I lent it to a friend and when I got it back the phone wasn't booting. I did a hard reset on the phone and it boots but the phone is not picking up any touch input ? I've done a factory reset from the image by holding
home, volume down and the home button, I've even put a new screen on and there is still no touch. I know the phone isn't freezing though because I'm able to navigate it with a mouse. Anyone got any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
I have a password protecting my phone and I broke the touchscreen how do I get in it. S6 edge
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Hi thanks everyone for your comments but wiping the cache actually sorted the issue? Tried multiple wipes and cleaning contacts.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Kallum Williams, Maybe try factory reset one more time. The phone worked when you gave it to your friend, you got it back and did not work, you replaced the screen assy, and still no touch. The phone may have been dropped again before you got it back and damaged the mother board or by chance you received a defective replacement display. You can tear the phone back down and clean all connections(Qtip dampened with 90% or better Isopropyl Alcohol), check all connection pins for damage, look at board for any loose/damaged/burnt components, etc.. Check battery voltage with DVOM while apart also, to make sure it is holding charge. Put phone back together and give it a try.
Factory reset:
Turn off your Samsung Galaxy S6 Edge.
Press and hold the volume up, home and power keys together.
When the device powers on and displays (Power on logo) release all keys and the Android icon will appear on the screen.
Wait until the Android recovery screen appears after about 20-40 seconds.
Using the volume down key, highlight the option, (wipe data/factory reset) and press the power key to select it.
Press the volume down button again until the option (Yes, delete all user data) is highlighted, then press the power key to select it.
After the reset is complete, highlight (Reboot system now) and hit the power key to restart the phone.
Good luck.
Bewertung 2
2 Kommentare:
same problem, but cannot even power down the phone
von
you will loss all data it is like factory rest ,please take before doing this
von
  1. Reboot Your Phone
  2. Reinsert the Sim Card
  3. Try to boot your phone at Safe mode
  4. Try reset your Phone
Source
Samsung Galaxy S6 edge Touch Screen Not Working
Bewertung 2
1 Kommentar:
Simple Steps
von
best way to replace the LCD . It happened with me and I replaced the whole LCD , there is no software issue
Bewertung 0
Antwort hinzufügen
Kallum Williams wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 45,763
