Zum Hauptinhalt wechseln
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
46 Fragen Alle anzeigen
My 1990 Honda accord EX-R hood latch is bent inward, how do I fix it?
I rear ended someone a couple weeks ago and i got a new hood for my 1990 honda accord but my hood wont shut flush. I looked at my hood latch and it is bent inward, is there anyway i can fix it myself, if so, how?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
diego tamesis , If you are talking about the hood latch on top of rad support they can be bent out fairly easy. Tie a rope/chain/cable around the area of the latch/cradle and the other end wraps around a 2x4, put a rag between 2x4 and bumper, now use the 2x4 to pry the hood latch/cradle into correct position. May have to fine tune with a heavy hammer and board. Ifyou are not removing any thing such as radiator,A/C condenser,etc. take your time and be careful as you do not to damage other parts. See the link below, same idea, just not as drastic. Good luck.
https://www.youtube.com/watch?v=Zr4grivK...
War diese Antwort hilfreich?
Bewertung 4
7 Kommentare:
Thank you so much! appreciate it
von
diego tamesis, your welcome, I have actually had to do this before on a friends car. If you like the answer, accept it thanks.
von
Hi @lpfaff1 ,
Is a 'heavy hammer' also known as an American screwdriver where you are as well? ;-)
von
jayeff, :-))) I have not heard it termed that way, but maybe by some!
von
I had heard of that but the urban dictionary has: http://www.urbandictionary.com/define.ph...
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
diego tamesis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 1,151
