Zum Hauptinhalt wechseln
Die achte Generation des Mitsubishi Lancer.
What is the best way to remove the alternator on a 2006 lancer 2L DOHC
I have a 2006 lancer 2.0L DOHC and the alternator is on the passenger side at the bottom of the motor which is the best way to get the alternator out does not look like it can com me straight out the top
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
This question was migrated from http://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@scullyjunior , Chris, It will come out the top with some wiggling/rotating/pulling. The link below has a pretty good step by step procedure for you to check out and image from link may also help. Good luck.
http://www.justanswer.com/mitsubishi/783...
War diese Antwort hilfreich?
Bewertung 2
Be aware its not as easy as it looks or seems in this car since the a/c line is right dead center of the alternator and the lower control arm is directly below it it definitely takes much longer frustrations then they say took me and my dad 4.5 hrs of cursing and snapping to get the old one out took less time to get the new ine in then it did to get the old one out
Bewertung 0
Antwort hinzufügen
Chris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 715
