Zum Hauptinhalt wechseln
Der Sharp EL-531X ist ein wissenschaftlicher Taschenrechner von Sharp.
How can I fix it?
MY calculator won't turn off except after being left alone for a long period of time and the buttons aren't responding. Also it only displays 0=. and I've even tried restarting it many times.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
The calculator will display 1 no matter with the battery or not.
It stop working.
von Teilen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
Try replacing the battery and then resetting the calculator.
The EL-531X uses a LR-44 (or equivalent) battery
Here are two images that show what to do.
Battery Replacement
Reset
(click on images to enlarge for better viewing)
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Hi. After changing battery and resetting, all the buttons still didn't work. Please help.
von Teilen
I had the same problem and managed to fix it by removing the battery and unscrewing and removing the back cover. That's it. I reckon that the issue happened because the "=" key connection was stuck, so uncovering the calculator might have "released" the connection. Hope this helps!
Bewertung 0
Antwort hinzufügen
fahimakhan2 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 46
Insgesamt: 5,330
