Zum Hauptinhalt wechseln
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
99 Fragen Alle anzeigen
How replace power button
please help how i can repair button phone dont turn on
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I need help to find where to get a new power bottom for Asus Zenfone 2
von
You can get it on Aliexpress.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@raw771 , Anton, Make sure battery is charged, try a different compatible charger if need be. Use the guide below to disassemble the device so you can disconnect the battery for 5 minutes,then plug back in and check/reseat all the connections to make sure all are connected well. Try and power on phone. Good luck.
Asus ZenFone 2 Motherboard Replacement
War diese Antwort hilfreich?
Bewertung 2
Unless you have a micro soldering setup, you must either send it in for repair, get a new motherboard, or a new phone. You can, however, keep using your phone as is, just don't ever let the battery die.
Bewertung -1
1 Kommentar:
Then whats the point of having a MOBILE phone? its anchored to the wall by a charger as (some) home phones are anchored to the wall by a jack.
von
Antwort hinzufügen
Anton wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 3,950
