Zum Hauptinhalt wechseln
Reparaturanleitung und Support für das ferngesteuerte Lightning McQueen Auto. 1:24-RC-Auto von Dickie Toys. Artikelnummer(n): 203089501 für den Basis-Lightning McQueen 203089538 für die Metallic-Variante
How can I remove the rear wheels?
The car does not have proper traction and I think there is a problem in the gearbox between electrical engine and rear wheels. I disassembled the car but I could not take out the engine and gear box because of the rear axle. I tried to pull off the rear wheels to remove the axle but it did not work. Any ideas how to do that?
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
If you supply pictures someone may be able to help you further.
von
I'm facing same problem from the very day it was delivered to me. Need urgent service
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The answer is: brute force.
The only way to remove the axle is by taking the wheels off first. They are pretty tight, but I managed to pry them off using a fork. Insert the fork all the way down behind the wheels, with the axle in between the tines of the fork. This will prevent the wheel from getting too damaged. Then use the leverage of the fork to pry the wheels off.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
On behalf of the5-year old boys community, THANK YOU!
von
Thank You!!
This helped me to fix Lightning (again).
My son is very happy now.
My wife not, because i bend the fork 🙈
von
Antwort hinzufügen
steffen.ruefer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 30
Insgesamt: 6,780
