Zum Hauptinhalt wechseln
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
1525 Fragen Alle anzeigen
Is it possible to replace the sim sensor
I had recently bought a iPhone off a friend who had never said the phone had damage. They had stated it had normal wear and tear. When I had went to turn the phone on I was told that the sim senor inside the phone was damaged hence it didn't read any sim card the lady was placing in. Does apple give any type of repair for that? What would need to be replaced? I took the phone to a third party and they said apple would fix it for 175$, does that sound about right?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
A new SIM card reader must be installed on the logic board so this requires a micro-soldering repair. IMHO, 175$ seems on the high side but it really depends on where you live.
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
the part is only about $4 too
von
@gigabit87898 The part cost doesn't always have much to do with the pricing of a repair. Some passives, like a ferrite bead (i.e. backlight filter) cost only a few cents but it can still be a 70-100$ repair. What's important in the final cost is the skill required, the difficulty of the repair, how much troubleshooting is required and the risk taken by the tech.
Some repairs are easy and others are quite complicated. Every time you start applying heat to the logic board, you take a certain risk of damaging something else.
For example, the SIM card reader is easily accessible (good) but requires a lot of heat (bad). Directly opposite the reader is the NAND. Too much heat and you could have problems. I would charge ~100$ but that's me. Others may have differing opinions.
von
Do you do repairs yourself?
von
Yes, check out my profile for my website and contact info. In the interest of transparency, there are several micro-solderers who are active on this forum.
von
Thank you I will check out your website. :)
von
Antwort hinzufügen
Huntingpanzer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,401
