Washer buttons won't stay on
When I press the power button, all lights power on then right back off. I replaced the dispenser PCB assembly, but that did not change anything.
Ist dies eine gute Frage?
First unplug it for five minutes to allow it to reset.
That failing take a look at my answer here:
War diese Antwort hilfreich?
@kodiakbear ,laurinda59 , unplug the washer for 5 minutes, then plug it back in and listen for a click. If no click possible bad CCU, also could be door lock switch faulty or bad connection, start switch and or timer faulty, washer motor faulty, main control board faulty or shorted. Check the links below for more trouble shooting info. the last link is the service manual that could help big time in diagnosing your issue. Good luck.
https://www.youtube.com/watch?v=YdWuLw15...
http://removeandreplace.com/2015/04/10/w...
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 5,759
1 Kommentar
Washer won't stay on. Lights do come on but turns off or just flashes. What could this be???
von bm97057
