Zum Hauptinhalt wechseln
The Canon EOS 5D Mark II is a 21.1-megapixel full-frame CMOS digital single-lens reflex (DSLR) camera with video recording capabilities.
49 Fragen Alle anzeigen
ALL batteries read as "empty" (flashing icon on top LCD).
I can't find anyone with a solid solution online.
Batteries that and confirmed to be good and charged will read as empty and my 5D mk II will not operate. Nothing on the rear LCD screen. Only a blinking empty battery on the top LCD. The top LCD comes to life and responds to settings changes (wheel to change aperture or shutter speed) for a second before becoming unresponsive and blinking the empty battery icon. I've replaced the internal "watch" battery.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I've done all these steps to no avail... It's hard to know if I've done the battery contact cleaning effectively, because it still doesn't work. So, did I not clean it properly? Or is it another issue entirely?
I have yet to find someone on the internet who has this exact problem with a 5d mk II (other cameras, yes... but not this one) let alone someone who has actually fixed it.
von
Hey Joel! Did you ever figure out how to fix this? I just opened my brand new Mark IV and it’s doinf the same thing
von
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
Joel Gautraud , Ensure batteries are indeed good and fully charged. Remove the card and try turning on, then put card back in and try. Still no go, check battery contacts in camera for damage and clean the battery compartment terminals with a pen eraser(a little more grit to remove corrosion/tarnish) or Qtip dampened with 90%+ Isopropyl Alcohol and blow out debri, check and clean battery terminals also, reinsert and try. Still no go try a reset/reboot, link below will take you through the reboot process. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://photography-on-the.net/forum/show...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I was getting the same issue and replacing the watch battery and using a genuine battery solved it for me!
von
Hi Joel et al.,
I had the same issue on Canon 5D Mark II and while looking for a solution hit a link to your question. Here are my findings to fix it.
My case:
I put in fully charged original Canon battery, checked with other cameras and with multimeter - it is in excellent condition and holds charge very well. Once I turn power on I see only battery sign flashing on top screen and nothing else happens. When I try switchers, buttons around the camera for some time the battery is not depleted - so there is no short circuit running. Interestingly when I open the battery compartment door with power ‘On’ and then close it with some pressure there is <1 sec blink on top screen of usual digits/parameters as it would be in usual working mode, but then it comes to an above described state. So I find the following issues to be checked, starting with ones mentioned earlier in the thread:
  1. Battery compartment door switch - it is tiny switch on the door that sometimes gets broken, another comment is describing how to check that. Be careful when playing with this switch, you can easily break it. I don’t think it will lead to blinking battery indicator, likely just won’t give you to switch the camera on.
  2. Maybe too obvious - try cleaning contacts, but if they are affected I would say you might have water damage and if it is inside battery compartment, it could be also on the power and main board.
  3. Another comment in this thread mentioned a data connector that is ‘supplying’ battery status information to main board - as of my experience even if you disconnect that cable it will just stop switching off when you open battery compartment door and doesn’t really block operation of the camera.
Now coming to the root of the problem in my case and something bit more complicated - power board plate / controller that is responsible to power supply from battery to all camera plates and components. It is located under top LCD screen and getting there requires taking out back and top covers - 5-10 mins when you know how to do it and 30 mins for the first time. This PCB contains several fuses to protect camera against short circuits and one of them had blown up. I had issue with ‘P’ fuse VD7-2291-001 that you can see on page 5 of Canon 5D Mark II Parts catalog C12-6201.
Easiest way to fix this is to replace the whole PCB part number CG2-2319-000 which will cost you around £30-60 itself or find and resolder the fuse impacted - which needs some good soldering experience as it is 2mm (SIC!) size fuse. You will need multimeter in ‘beep’ mode to test lettered fuses shown on the scheme - one or several might need a replacement. I am engineer by background, but never touched any of the above mentioned devices for more than a decade, so it was a new [re]learning experience and after some time spent on watching YouTube videos and looking for manuals and ordering fuses I managed to successfully resolder fuse in question and fix the issue. Looking back: if you are fixing only one camera I would strongly recommend just replacing the whole PCB. This will require only a screwdriver, new PCB and a pair of good hands.
I did the above mentioned exercise for one of 3 Canon 5D Mark II I bought specifically to play with their electronics and try fixing them. They had essentially same issue - please see description below that might help in your case:
Second camera was not switching on at all, simply no reaction. Issue was another ‘N’ fuse blown up on PCB, again either resolder it or replace PCB. Rest was working perfectly.
Third camera also was not switching on at all, but interestingly did show some signs of water damage - so when I opened it to check PCB, the board itself was perfectly working, but there was a corrosion sign on the data cable (CH1-8590 that you can see in manual mentioned above) connecting PCB to Main board. Corrosion affected one of copper connector threads breaking it for 1mm and thus not allowing to transfer signal. I cleaned the plate and affected areas with 45% phosphoric acid and after examining them replaced this connector, all the rest was working perfectly.
So at the end of the day looks like power board is the first suspect you need to check to fix power issue with Canon 5D cameras. Important conclusion from here - if your camera fell into water, first thing take out the battery ASAP and wither send it to service or open up to dry out boards, especially if it is salt water that will corrode all connections.
I hope this write-up is helpful. I am first time at this website and maybe will add step-by-step instructions with pictures as fully understand seeing how to do all this would be way more helpful.
Kind regards,
Ton618
Bewertung 2
Thank you @ton618, your answer was the most relevant and informative that I've found on this topic. I had a similar issue but the cause was different, so I'll explain here so others can benefit.
My Canon 7D fell about two feet onto pavement. After that the camera would do nothing except show the blinking battery symbol on the top LCD. If a fully charged battery was left in overnight it would be dead by morning. I also have a 5Dii and a charger which shows charge level that I could use to verify the state of the battery.
The cause was one of two (or both) things.
First the power board (as described by @ton618 ) has a metal shield over it, top and bottom, presumably to shield the rest of the camera from the EMI that switching regulators will generate. Three edges of the top shield are held in place by very small clips on the PCB. That shield had escaped its clips from the shock of the drop and could have been shorting some components on the power board.
Second, the power board is held in place by two screws and connects to the motherboard by one of the long rectangular push-on type of connectors. There is no cable in between, each side of the connector is soldered directly to the PCB it is on. The holes in the power board are a fair bit larger than the screws so there is ample opportunity for the connector to be poorly connected, or even not connected at all. In my case the power board looks as if it may have rotated a bit, causing some of the pins in the connector to lose contact.
After re-seating the metal shield into its clips and reorienting the power board to mate the connector correctly, everything works again.
Bewertung 1
Hi,
I’ve had this issue.
It turned out to be the battery door microswitch.
With the battery in, open the door and press the microswitch to verify if it’s the problem.
Bewertung 0
This is a very late answer but I hope it will help other users.
There is a ribbon cable that runs from the battery “C” contact to the mainboard and it is the only thing that the camera uses to read the status of the battery.
If it were damaged the battery would be considered empty no matter what.
Otherwise you are probably having issues on the mainboard.
By no means it is an easy fix and I’d say replacing the mainboard is actually easier.
Bewertung 0
I have a Canon 5D Mark ii. It has no problem when I use it with the stock LP-E6 battery. But recently I got a dummy LP-E6 battery box that can connect to external USB-C charger. When I use the dummy battery, the empty battery sign always blinking and the camera can not function. However, if I open the battery cover and close it, all function well. It seems everytime I turn on the camera power switch or USB-C charger, I need to open and close the battery door to “activate” it. A bit annoying but it does work in this week. I could not explain why though. just to share.
Bewertung 0
Antwort hinzufügen
Joel Gautraud wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 69
Insgesamt: 6,043
