How to assemble all the parts - cables and connections
Answer continued from below page:
Ist dies eine gute Frage?
Steps
Well, that about covers it. If I missed something, nothing could be critical to the system.
If you plan on putting Windows on it, simply use the Windows Media creation tool to create a bootable USB drive to install Windows from. Done plenty of times, very simple. Instructions here: https://support.microsoft.com/en-us/help...
Hope this helps!
If I did forget something, just say what's not happening!
War diese Antwort hilfreich?
I have noticed Windows Media creation tool isn't available anymore, so if I can I'll edit my answer to include the .exe for the software. (An .exe is a file type that windows recognizes as a program it can open.)
@pccheese - thanks for your answer on the PSU connectors. I have a question on the below chart so I am posting my question here. I have only been able to do the B, G and F connection from below chart and have no clue about others. Can you advise if the other connections are required as well?
You will be my GURU for my modern PC built, if I dare to do so, and you don't mind :)
Does your case have firewire or rs-232c port? If not, your good to go. Can't wait for that PC to get going. I take much pride when working on my PC, and I hope you do too. High five! Where some of the few people that save nearly half the cost of pre-built PC by doing it ourselves.
I will be your Guru under one condition, and that is you must meditate on the digital physics of a linear diode transmitter inside the themographical core of a transistor semiconductor based processor. Got it? Meditate til' you levitate, man!
Ok, got everything except SATA cable which the local shop is selling super expensive and some peripheral cables. Will post once everything is setup. Thanks again for all your support.
B&H has SATA cables pretty cheap. Best buy should have a few in stock.
Did you get the SATA?
Wasn't finding the ones under my budget - so i'm ordering it from ebay. C$5 for SATA cable and $5 for VGA cable, will arrive in 2-10 days. I have to get a cheap monitor as well. May I ask how much would you have spent on such machine, I think I would end up spending around C$150 total.
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 8
Insgesamt: 531
4 Kommentare
You're awesome. Thanks a lot for your great support. I'll let you know how it goes.
von Sud Tiwari
Have you started yet?
I forgot to mention ESD safety. Google it and select your favorite source to read from.
To prevent it, simply keep hand/arm contact on the metal part of the case to keep it grounded. Try avoiding static electricity including carpets.
von George A.
Just came back from my work and started working on it. I have 2 questions for now:-
Q1. Manual Pg # 51 - it tells to connect 2 chassis fan cables to 2 fan header in Mobo, I don't see these cables anywhere, is it one of the cables coming from PSU? There's only 1 cable coming from my fan which is already connected to a different slot (it was preassembled).
Q2. Pg # 52 - it tells to connect 2 X 12 cable and 2 X 2 cable between PSU and Mobo, which I have done. But, there are so many other cables coming out of PSU, where do they connect. I am bit confused looking at those cables.
**I don't have a GPU yet, is it mandatory for my computer to operate?
von Sud Tiwari
Q1: Just unplug from where ever it's plugged into and plug it into the mobo. The motherboard needs at least one fan plugged into it to boot (besides the cpu fan).
Q2: A psu has a whole lot of extra power connectors built in for expandability. I don't know what PSU you have, but I'll assume It's low end (like mine). You should have four SATA power connecters, four molex connectors, a motherboard connector, a CPU connecter, and a GPU connector. You will use a CPU, mobo, and sata connector. You have extra molex connectors for legacy devices and fans (an adapter is necessary for fans). The three extra SATA connectors are for adding drives, like a DVD drive, secondary HDD, and maybe a backup HDD. There is also a GPU connector for adding a GPU. I recommend tying them up with a twist tie and neatly stowing your extra cables.
And no, you will not need a discreet GPU for this system, because the motherboard has a low power one built in. As long as you don't do anything GPU heavy such as 3D modeling, games (not including solitaire), or video encoding, you should be fine.
BTW, when you get serious and build a full fledged modern PC, I would honestly appreciate it if you asked for my advice on getting components. I've got my head wrapped around spec sheets, and I'd like to do something with that knowledge.
von George A.
