Zum Hauptinhalt wechseln
Das Apple iPhone 5s wurde am 10. September 2013 angekündigt. Die Reparatur dieses Geräts ist ähnlich wie bei den Vorgängermodellen und erfordert Schraubendreher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA mit 16, 32 oder 64 GB in silber, gold und space grau.
3530 Fragen Alle anzeigen
Drop on back bootloop, repair shop fail
I'm currently travelling, and whilst in Cuba I proceed to drop my phone flat on its back which causes it to bootloop. This happened to me in Canada as well, where I opened it up reseated the display cables and was good to go, when I tried this in Cuba, it did not solve the problem. It was and is still in a bootloop on the apple logo and then black.
From research on this site I assumed it was an issue with the battery, so I have taken it to a repair shop where they reseated it and tried a new one, but it failed to fix the issue. It is still in a bootloop.
They gave a load of excuses and no real reason to why it is broken other than my jailbreak my have been the cause, which I find very hard to believe. They then suggest that I try a restore, which I have just attempted to which I get error (9). Which I think means a hardware issue.
If the battery is not the issue, the only hardware problem I can think of is from screwing the wrong screws on the guard of the display cables, would this be the cause? How do I go about checking this and fixing it?
iPhone 5s 10.2
Jailbroken Yalu b7
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
Did you try a DFU mode restore?
von
I haven't, sadly my laptop has died so cannot restore at this point, I will give this a go once i get my laptop repaired
von
Finally have my laptop up and running and sadly this does not work, DFU restore simply returns the same error 9
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
on my quick 2 minute research it seems error 9 is an error in updating i have found this link though witch could help a lot.
How to fix iTunes error 9
War diese Antwort hilfreich?
Bewertung 1
For me it sounds like a corrupted NAND
Bewertung 0
3 Kommentare:
what does that entail? sorry no phone and now no laptop, whilst half way across the world, so can't effectively google
von
This is the device's memory chip.
von
Sweet, apologies for my ignorance, I'll email some repair shops see if they can fix this issue
von
Antwort hinzufügen
charlie.smith142 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 73
