My lenovo a6000 cant power on
I have a problem with my lenovo a 6000, the phone cannot turn the power on but still ok with charging. I have check the battery and the condition is ok . Anyone can HELP me to solve my problem?
Ist dies eine gute Frage?
On a lot of the lenovo tablets and phones there is a reset button in the SD card slot you will need to reset it. Not sure on your model but its worth a look . If theres not one then try removing the battery then leave it sit for an hour and then put the battery back in and reboot the phone . While you have the battery out it wouldnt hurt to check the battery with a multi meter against the power out specs listed on the battery. Hope this helps
War diese Antwort hilfreich?
Muito bem gostei
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 8,079
4 Kommentare
Does the phone instantly shut off when you unplug the charger? If so then the battery is probably unable to hold a charge and needs to be replaced,
von Jacob Micallef
My Lenovo A6000 shutdown on recovery mode .. now dosnot turned on ..wht can i do ??? Plz help
von Akshay panigrahi
von Golu Kasar
Esta tudo bem sta vez,
von Masawa Luis
