My phone cannot make acall
when i press to call it says( Not registerd on network)
Ist dies eine gute Frage?
fadul babker info. from link below, Samsung galaxy not registered on network error occurs when you attempt to make a call or text. Your current Service Provider is not notified of your IMEI number, and then you get this error on the pop-up screen ” not registered on a network”.
Use the links below to hopefully solve your issue or drop in and see your service provider if able. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
War diese Antwort hilfreich?
Not Registered on Network error is associated with mobile carrier network you get when there is some conflict with mobile network reception or SIM card. any attempt to make a call will display a pop-up “Not registered on network”. This can be caused by a series of errors including poor reception, SIM card registration fails, No network access in your area, etc. The error can occur on any smartphone including Samsung and others.
And finally, don’t forget to check with your network provider and check is the connection is active.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 129
