Zum Hauptinhalt wechseln
Eine TV Spielkonsole von Sony Entertainment, auch bekannt als PS4. Sie wurde am 20. Februar 2013 angekündigt und kam am 15. November 2013 auf den Markt.
1697 Fragen Alle anzeigen
Optical drive not spinning up
I installed a new disc drive into my ps4 and every thing worked fine untill I switched the drive board and now the disc drive won't spin the discs anymore. It just makes a clicking sound and won't recognize any disc. I noticed when I move the big ribbon cabble a little bit that the disc starts spinning for a moment, but stops right after. What can I do now?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Most likely when you removed that large flat ribbon cable the ears were damaged or torn off. This causes the ribbon cable to not align correctly when you put it back in. Many times the little ears get stuck inside the connector which will make it very difficult to plug the cable in completely.
You might try a new cable as long as those ears aren't stuck inside the connector.
Hope this helps.
War diese Antwort hilfreich?
Bewertung 1
Hello and thank you for your support.
I bought a new ribbon cable and it changed nothing. I don't understand why it won't work. Everything seems to work fine.
Bewertung 0
1 Kommentar:
Hey, did you find a way to get it to spin after all ? Thanks.
von
Antwort hinzufügen
AlessioM wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 3,399
