Date and Time Settings - Samsung Galaxy Note® Tablet 10.1
From a Home screen, tap Apps icon Applications icon > Settings > Date and time.
NoteIf Settings isn't available, ensure that the Apps tab is selected.
To use network-provided values, tap the following:
Note Enabled when a check mark is present.
Automatic date & time
Automatic time zone
If preferred, manually adjust settings (Date, Time, Time zone) as appropriate.
Note To manually adjust settings, Automatic date & time and time zone must be disabled (un-checked).
If desired, tap Use 24-hour format.
Tap Tap date format then choose an option (e.g., 12/31/2014, etc.).
This may be a flaw in this model. Many others have the same issue:
https://www.cnet.com/forums/discussions/...
http://forums.androidcentral.com/samsung...
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
