Zum Hauptinhalt wechseln
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
20 Fragen Alle anzeigen
after lcd replacement iPhone wont turn on
HI GUYS ,
ITS very simple , after i replaced my iphone 6+ lcd , my lcd wont turn on i plugged to pc it recognized but still wont turn on ,and i can feel its charging . But when i put back my old lcd cracked it turns on and work just fine ,by the way i tried 3 different lcd
can any one help , i will really appreciate thanks
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare
Could it possibly be 3 lcds from the same batch its possible you could have gotten a bulk batch of bad screens. it happens somtimes i would order another lcd and try
von
Thanks for replying , you know the first lcd are from the same batch ,but the third from another lol ,thats why it driving me crazy
von
Who do you get your parts from?
von
HI , yes i did it but nothing,
i tried another company LCD from 3 different distributor , been recognized by iTunes ,still no image on LCD, i did try to press down ,without damaging the mother board still at square on , i tough it was the flex from the metal shield i did changed it nothing , and again still functioning with the old LCD
loll look likes a FRIDAY 13 MOVIES getting nuts
thanks for all answer
but i.m still looking for an answer
von
[image|1067973][image|1067972][image|1067970]
theres the image of the connector on lcd and phone
looking for answer thanks
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
I would definitely try another company's screen for a last ditch effort and make sure the lcd connector is seated fully. Sometimes the connectors on the aftermarket screens aren't made exactly the same and you'll think they're pressed down all the way but they wont be making full contact. Sounds like you've done exactly what any technician at any shop would have done so far, you're on the right track. Let me know if this helps
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hi everyone ,
i did tried another company LCD from 3 different distributor , but nothing than been recognized by iTunes ,still no image on LCD, i did try to press down ,without damaging the mother board still at square on , i tough it was the flex from the metal shield i did changed it nothing , and again still functioning with the old LCD
von
take a look at the bottom edge LCD, does the LED come out? if yes the problem is on the data path between LCD and CPU, actual data path very rarely broken even if exposed to corrosion, try to clean the socket on the motherboard and try. if its doesn works, resolder the socket on motherboard. i hope this helps
Bewertung 0
1 Kommentar:
hey .
i did already connect to pc and i tune it recognized,it happened only with aftermarket lcd ??? thanks
von
Your lcd may not compatible with your iphone.
your iphone starts but its display remain blank. try to call on your iphone number does it ring or not. if your iphone ring then we can say that display remain blank but iphone is working and problem with your new lcd.
also try to connect your iphone to computer. does iphone recognize by computer or not.
here is more detail troubleshooting for iphone ipad wont turn on black screen.
http://ipodtips-tricks.blogspot.in/2016/...
Bewertung 0
1 Kommentar:
Hi Senata
i did tried what you told me but i will take a look at the links thanks
von
Antwort hinzufügen
m lies wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 112
