Zum Hauptinhalt wechseln
Wont turn on after new battery and cleaning the motherboard
Hi, im looking for a solution for my gameboy Micro (now i have 2) ones works perfectly and the other one wont turn on at all, tried to use the same good battery i have (didn't work), when i plug in the gameboy to the wall charger the blue leds blinks once and thats all
tested the screen and speakers on my good gameboy and they work so the problem must be on the motherboard itself
any solution will be very appreciated
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
You should get a Multimeter and check if the motherboard have been short-circuited, maybe you had some static electricity in you when you touched the Gameboy's motherboard which ruins a motherboard. I advise you to get a Multimeter and check the motherboard still gives the right positive and negative charges.
Versatile multimeter with all the right functions for basic electronics troubleshooting. Bild
Produkt
Digital Multimeter
$59.95
War diese Antwort hilfreich?
Bewertung 0
First, I would try a new battery. They start at around $10 for 460mAh or $15 for 600 mAh. But use your known good battery from your other GBM first.
If the problem persists, you most likely have a bad cap or resister on the motherboard. You'll have to test for continuity with a multimeter.
Bewertung 0
Antwort hinzufügen
Cesar Melendrez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 46
Insgesamt: 771
