Zum Hauptinhalt wechseln
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
Cam sensor location no spark issue
I have been trying to get this car going for about a year.told that the cam sensor is gone and need to replace it.now I'm no expert but I do know that I have watched a few videos on YouTube and where they show the cam sensor to be at it isn't..Then told that it's apart of the distributer shaft.!!!!! So if that's the cam where's the Crank shaft sensor? I ts a no spark issue
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@lowvisions , Patrick , On the 2.2l engine, crank position sensor is behind the crank shaft pulley/balancer. Picture below(crank sensor circled). For the V6 3.0l almost same position, see video link. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=M6zU6jh8...
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
I'm sorry I should of mentioned that I have a 3.0
von
Patrick, For the V6 3.0l almost same position, see video link. Thanks for replying back.
von
On the 2.2 do u have to take the timing cover off to get to the sensor
von
We have a 1996 Camry LE 2.2L 4 Cylinder... I have bought the crankshaft position sensor, I just dont know where the heck to install it, where is the old one? Anyone know? I searched it up on youtube but i could not find anything. I hope someone can help
von
Hi for all Ihave toyota corolla 1993there’s no cranck shaft sensor but there's acumshaft sensor biultin within the main distributor shaft making signale to the ECU of the car
Bewertung 0
2 Kommentare:
Well I have remove my 2.0 l and installed a 2.2 l engine , and the car didn't use a distributor , it uses coil which depend on a crankshaft sensor
von
@elicaannephembani And the point of bumping a thread that's almost 2yrs old is...? Are you having issues? Or what?
von
Antwort hinzufügen
Patrick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 104
Insgesamt: 9,958
