Zum Hauptinhalt wechseln
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 Fragen Alle anzeigen
Mini USB receiver end in calculator is broken, how do I replace that?
The pins in the calculator are bent in, preventing a charge. I was wondering if I would be able to buy a new female end, open the calculator and resolder it in if that's even possible.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@ow0 , ow0, Maybe try straightening pins carefully with a toothpick, if no success then consider the changing of port. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide to get you inside the calculator to check the charge port and will also post a link(not your device/same repair) showing what is involved in repairing a mini USB attached to the board in case you would like to give it a whirl. If not wanting to do the repair yourself have a good computer/cell phone repair shop have a look and estimate repair. You may have to find/match visually replacement port, when doing a search. Good luck.
https://www.youtube.com/watch?v=Fdt1zGb0...
https://www.youtube.com/watch?v=rTim6FIJ...
War diese Antwort hilfreich?
Bewertung 4
Antwort hinzufügen
ow0 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 1,625
