Zum Hauptinhalt wechseln
Eine TV Spielkonsole von Sony Entertainment, auch bekannt als PS4. Sie wurde am 20. Februar 2013 angekündigt und kam am 15. November 2013 auf den Markt.
1697 Fragen Alle anzeigen
need a schematic of ps4 motherboard cuh 1004a
hi every1 im new here and i need help from you
ihave ps4 with hdmi problem because i broke some component in motherboard
(hdmi capacitors + diods ) so for that i need a schematic
specially the hdmi schematic
and thanks in advance
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
As far as I know, there are no schematic/boardview/service manuals available for the PS4 yet. Your best bet would be to buy a broken PS4 and take the required capacitors and diodes from the dead board. I am sure 3rd party PS4 repair centres will have some dead boards lying about...
War diese Antwort hilfreich?
Bewertung 4
5 Kommentare:
any other sollution than that?
von
Unless you are able to get a schematic and board view for this, no other solution, unless someone knows the value of the components required.
von
Couldn't he just buy the right size ones on ebay
von
mr gamer 3002 pro ps4 nobody knows what the right values are . It's not the size that matters it's the electronic properties of the component that matters. So no you can't just go and buy something,
von
if you have same mother bord can replce same part then its wok
von
I've been looking hard. Found this, among others, for the diode values. I'm still looking for the resisters. Will post when I find.
Bewertung 1
1 Kommentar:
The 3 circled are a DZ2705600L.
https://www.ebay.com/itm/254629809041
von
Can't say for sure because I haven't tried yet (I'm having the same problem) but I think this is at least one of them
http://www.mouser.com/ProductDetail/Taiw...
Bewertung 0
Antwort hinzufügen
Simioli Moh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 65
Insgesamt: 19,892
