Zum Hauptinhalt wechseln
Repair guides and troubleshooting for Presario CQ58 series. These are budget laptops made by Compaq, which was owned by HP from 2002 to 2013.
22 Fragen Alle anzeigen
My Laptop can not produce sound when I connect headsets
My laptop can produce sound, disregarding the fact that i updated the sound-drivers when i i connect the headsets, but the pc's speaker does, but it dos not work with headsets.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi, When you plug a headset into the earphones socket does it disconnect the sound from the main speakers?
von
yes, that's what happens
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi,
Have to ask, you did try another set of headphones didn't you?
It may be that there is a faulty or loose audio output socket in the laptop.
Unfortunately it appears as though the socket is directly mounted onto the motherboard.
Here is a link to the service manual for your laptop. On p.62 it details the necessary pre-requisites and then the procedure to remove the systemboard. You may not have to go this far to initially prove whether the socket is loose or not.
If it is deemed to be faulty then you will need to have the necessary SMD (surface mounted device) soldering skills and tools to remove and replace the socket.
If this seems to daunting for you to do, contact a laptop repair service and ask for a quote to repair the socket.
If you really wish to use headphones and a repair is not an option you could try this alternative solution.
Hopefully this is of some help.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
thanks for A TIP.. will do that
von
Check your sound settings in "system preferences". Under output select "external headphones?
Bewertung 0
2 Kommentare:
will try that, thanks for a tip
von
i tried that but nothing worked
von
Antwort hinzufügen
bernardkathewera wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 121
