How do I put in a new SD card?
My old SD card is full and I don't know how to put in a new one.
Ist dies eine gute Frage?
Hi David,
To replace your SD card,
Step 1: Open battery cover.
Step 2: The SD card is located in a slot right next to the batteries.
Step 3: Using your nail, briefly push down on the SD card and let go immediately. Make sure you notice the way the SD card is oriented.
Step 4: With the new SD card oriented so the wording is right side up, make sure the switch found on the side of the card is slid up, in the unlocked position.
Step 5: Orienting the new SD card as you observed the old one to have been, insert it into the slot, until you feel a slight click, and the card remains fully within the slot (it shouldn't pop back up).
Step 6: Close battery cover.
Good Luck!
War diese Antwort hilfreich?
@dsepulveda , David, Turn off the camera power whenever the memory card is being inserted or removed. SD card can be found in the same chamber as the batteries under the battery cover. You may have to push card in with finger a little to get it to eject. For more details see the manual(link below, user manual Samsung S760)
Page 10-14 is about location/loading/unloading memory and other info., about card. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.camera-usermanual.com/manuals... Go down to page 13, that will instruct you on how to do it.
If this answered your question, please hit the accept answer button!
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 29
Insgesamt: 318
