Hello I had this same problem. I the moment i plugged in the charger it says battery temp too high shutting down to cool; i was unable to charge the battery. I tried without charging cable and i used a battery temperature app and i was getting erratic readings like -2 F to 0 F and then when i would put in my sim card or try to use any apps it would shoot up to 180 F and shut off my phone. Eventually there was no more power and i was unable to charge my phone. I figured it was the temperature sensor getting loose from dropping the phone.
I thought the sensor was on the battery itself so i bought a new battery but still the same problem; i tried disconnecting various components liek camera, lcd screen, charging port, camera, to no avail.
How i fixed: I removed the motherboard itself and got a heatgun and heated up the motherboard to try and “reflow” the solder,
I laid it on the concrete with the motherboard upside down and heated it by pointing at the square heatsinks on the rear of the motherboard, i did this for less than 2 minutes, assembled everything and now my temperature is reading correctly at 86 F and i’m now currently charging my new battery.
Good luck!
TLDR; a solder or electrical connection got cracked or loose on the motherboard and it needs to be “reglued” back on by using heat
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
